1 - 2 of 2 Posts
My right caliper sticks, do the make a repair or help kit for our birds that have new caliper pins??
if they are removable I just need to take the torx bolts out right?
What size torx bit do I need?
thanks, chad.
caliper slide pins
I can't remember what size torx you need but you can take them out. I usually buff them clean & smooth, then put silglide (brake lube) on them and the rubber sleeve and reinstall them. I hope that is the only problem with them because sometimes the caliper itself sticks. good luck
1 - 2 of 2 Posts
