No. The heat from the weld will ruin the chrome plating. It will discolor and may peel off. Both my brothers are welders and I've learned a few things from em. If you need any high quality work done just give me a ring. I'm sure they'll be more than happy to help ya out for alot cheaper than anyone else.
Eleventeenth Gear Poster
I guess I should have mentioned it in the first post....I dont care what happens to the chrome plating. Other than pealing and/or discoloring of the chrome, will the welds hold as well as if it was welded on raw metal?
BTW, I remembered you telling me your brothers weld, so I already you/them in mind :D
I can ask about the strength factor. I guess if you were to peel the chrome off first, then weld it to whatever you need to use, I think the strength factor won't matter. I'll ask tomorrow and double check.
