i had to pull a fuse to shut the car off today. the key turns but the power stays on. i know there was a post about this but i cannot find it. any help would be great!
If the key spins freely in the tumbler, there's a module about halfway down the steering column, that may have gone loose. Happened to me
looks like i will have to change the steering colum as i see the pin that came out and i did get it in place but it seems like it will just fall out again. im now starting the car with the white box. it wil have to wait until warmer weather.
i am having the same issue, i thought i need to replace that ignition switch "white box" but that wasnt the problem when i put it back together.
The Band, not the Disease!
Does your key spin freely? I had a piece in the tumbler fail. Took it apart an it was an easy fix.
yeah it spins freely, but now i am just using the white box.......
Any pics of the fix? Mine happened when I was turning right onto a main road. It refused to turn, so I forcefully urged it on and now I have to pull the 20A under the hood to shut it off. Any pics of what I should be looking for an a way to Jerry-rig it to work?
