1 - 13 of 13 Posts
while driving my car will try to die and then it accelerates on its own same thing on reverse , i cant drive it anywhere because it will die and its scary when it tries to speed on its own :confused:, what could it be guys ?
btw 93 sc
they all look nice and tight and they all have zip ties on them
Sounds like the IAC is going out. It did the same thing in my 89 when it went out, and also in my 5.0 when it did.
ya i was thinking that too and some members at sccoa told me about it , but they also said that if i disconnect the iac while running the car should stall , that means it should be doing its job , mine stalls when i disconnect it.
does it only do it when it warms up? The 89-93 design, the insides of em were plastic, the new and improved design on the 4.6l were metal. I disconnected mine too and it stalled. Let it warm up, then disconnect it.
ok will try that thanks
my 2004 3.8 mustang used to do that...throttle would stick while slowing down or would bog down--car was in Neutral...never could quite get it right and didn't trust the stealership to not F anything up with warrentee work so didn't fix it...
my moms windstar does the same thing. im thinking it has a vaccum leak because when i first start it, it will jump up to about 2k for about 3 seconds then slowly decrease to about 1100 RPM's then will stay there for about 1 minute and hit its idle at about 700-800 rpms
any idea?
ok if it is the IAC , it should make a sound like a goose on Crack LOL and yea i agree IAC mine did the same thing about 8 month ago
another vote for the IAC. If you get a new one, make sure it specific for your car. If it doesnt look the same as stock then dont even waste your time. I know this from experience.
sry i didn't post back, mine was a ground problem , negative battery post to radiator frame ..
but then again i replaced the iac and tps when i replaced the supercharger assy from another car
why do you say this? mine occasionally makes this loud humming noise that increases/decreases with a slight movement of the throttle, but a quick jab of the throttle will cause it to go away. I know my IAC is bad because I do get a high idle occasionally (only when its warmer out it seems.) I originally thought it was a small vacuum leak I had, but after replacing the line it still has done it. why would the IAC cause this?
BTW, this is on a 94 4.6, not a SC.
1 - 13 of 13 Posts
