OKay guys I am looking for a car cover for my car, must be for outside use. Any good sites? I found a good one for $110 from cover rite.
Also do you guys vote for hood protector or full bra? Also where can I get these? Thanks very much!!
Car it is for 1994 SC.
You should not be using a car cover if the car is outdoors.
The cover moving in the wind is enough to chaffe the paint.
The car is better off indoors :).
Your other question - get the full bra! I have very little experience with car bra's, but the CoverCraft bra I bought for the Marquis is very nice - soft backing, nice tight fit, and thick vinyl.
Thanks
Thanks soop those links worked really well I think I am going to get the Colgan car bra.
MercCougarXR7--I wish I had a garage for it but I don't so I am going to get a good car cover none of those cheap vinyl ones....
Hey, I have the same dilema - have to keep my car outside :( . Few words of advice - I got a size 3 cover and it was too small (maybe just cuz of body kit), but no place had a size 4 in the ood ones. Another option is this carport thing I am gonna get. It is $160 and it uses metal piping w/ fittings and tarps to make a sort of "garage" for your car. watch out for the cover blowing away, hold it down with something.
Bras are fine for trips, but if used for daily use, you will damage the paint from the wind moving it a little all the time the car is moving. If you are set on using one all the time, clean the front of the car good, and then put 3 coats of wax on it. It will give the hood some protection. Pull the bra off once a month, and wash and rewax.
