Car hesitates under mid acceleration after installing fog lights
I just put some Pilot fog lights on my car (BTW very nice :D will post some pics later on). I found out I had alot of corrision on my positive battery terminal so I cleaned it off. So the next morning the car started better with no hard cranking and the CEL was off (it was on because of the EGR Valve). But when I went driving it was like hesitating under mid throttle, although after driving for a little while it got a little better. Is this normal after removing the positive battery cable.
Thanks
Don
you reset the ecu ford recomends and its in your manual that you let the car idle for a few minutes after reconnecting the batt to allow the ecu to relearn
Look up 'ford drive cycle' on google.
There is a method to make sure everything gets reset; and there are settings for ac on and ac off.
