CAR MATH CALCULATORS
HP NEEDED TO SUSTAIN A GIVEN MPH
http://www.prestage.com/carmath/calc_HPtoSustainMPH.asp
HP FROM ET AND LBS.
http://www.prestage.com/carmath/calc_HP_fromETandWeight.asp
http://www.aspracing.com/dyno.htm
HP FROM LBS. AND MPH
http://www.prestage.com/carmath/calc_HP_fromMPHandWeight.asp
HP AND RWHP FROM LBS., MPH, AND ET
http://www.gordon-glasgow.org/hpcalc.html
HP FROM ET AND MPH
http://www.mustangworks.com/analyzer.html
ET AND MPH FROM RWHP AND LBS.
HEADER LENGTH
http://www.prestage.com/carmath/calc_headerlength.asp
G FORCE AT 60'
http://www.prestage.com/carmath/calc_60.asp
CARBURETOR - WHAT SIZE - AIR CAPACITY
http://www.prestage.com/carmath/calc_AirCapacity.asp
http://www.prestage.com/carmath/calc_CarbSize.asp
http://www.classictruckshop.com/garage/shopmathcfm1.asp
ENGINE DISPLACEMENT
http://www.prestage.com/carmath/calc_cid.asp
ENGINE DECK HEIGHT OR COMPRESSION OR CC OR DISPLACMENT
http://www.classictruckshop.com/garage/shopmathengine1.asp
ENGINE COMPRESSION RATIO
http://www.prestage.com/carmath/calc_compression.asp
ENGINE PISTON SPEED
http://www.prestage.com/carmath/calc_pistonspeed.asp
ENGINE FUEL NEEDS AT WIDE OPEN THROTTLE
http://www.prestage.com/carmath/calc_fuel.asp
GEAR RATIO
http://www.prestage.com/carmath/calc_Gears.asp
SPEEDOMETER ERROR ON TIRE CHANGE
http://www.prestage.com/carmath/Speedo.asp
AERODYNAMIC DRAG
http://www.ihonk.com/h/speedcalculators/racing.html
ELEVATION POWER LOSS
TRANSMISSION OPTIMUM SHIFT POINTS
http://www.prestage.com/carmath/dynochart.asp
TREMEC GEARS 3550 TKO
http://www.ttcautomotive.com/products/tremec/tr-3550.htm
TREMEC GEARS T56
http://www.ttcautomotive.com/products/tremec/t-56.htm
TIRE SIZE CALCULATOR - SHOWS OLD AND NEW IN SCALE
http://www.miata.net/garage/tirecalc.html
MILES PER GALLON FROM MILES AND GALLONS (near bottom)
http://www.forerunners.com/ss/math.htm
OPTIMUM GEAR RATIO FINDER FROM MPH, TIRE AND HP (2nd from bottom)
TOP SPEED VS RPM FINDER (last one)
FUEL SYSTEM ANALYZER FROM HP, INJECTORS, BOOST, INDUCTION
(3rd from bottom)
79-93 FOX MUSTANG ENGINE VIN DECODER
http://members.tripod.com/fast_wheels/engine-lm.htm
64-73 FOX MUSTANG ENGINE VIN DECODER
http://members.tripod.com/fast_wheels/engine-em.htm
AIR FILTER FORMULAS (at 3/4 down of page)
http://www.knfilters.com/facts.htm
http://www.performanceunlimited.com/documents/filtercalc.html
GOD WORKS WITH YOU NOT FOR YOU
i would bet that most of these formulas are greatly simplified, and don't take into account real-world forces, such as friction. However, they can be fun to play with and can give you a general idea of whats going on.
