Hello all...I have a 1994 Thunderbird with the 4.6L V8. My car will not idle at the proper RPM. The idle is too low, at approximately 600 RPM. If I try to turn on the A/C the car stalls. I changed the I.A.C. valve, spark plugs (gap 0.52), and cleaned out the throttle valve but there has been no change. I was and still am getting a check engine light.
Does anyone have any suggestions?
Thank you in advance.
check to see what the check engine code is first and go from there...
there are sensors you can clean with throttlebody/intake cleaner to make it perform better.
DPFE sensor i bet
