Trumpeter Extraordinaire
Hello, and welcome to the forums.
A possible cause of wobbling (or shaking) may be a bad wheel bearing. There's a number of other reasons listed in the service manual that can cause vibration or shaking. These include (but aren't limited to) wheel alignment, wheel balance, driveshaft balance, worn U-joints....
Try a search here, using shaking or vibration, for example, and see what others have suggested.
Good luck to you.
how long has it been doing this? did it suddenly start? if it did then it'd not the wheel bearing, have somone drive your car and have a look at the wheel that is giving you trouble.
you might want to check out this website, it will explain all possible wheel parameters in detail.
http://www.chris-longhurst.com/carbibles/index.html
have a look at his "suspension" and "wheel and tire" links on the sidebar, it will tell you a lot about how it works and what problems each kind causes.
D
