I got a 95 V8 T-bird, and lately when i try to start the car it would click as if the battery was dead, but if i turn the key again it would start or if i hold the key in the starting position the car would start. Now the car wont start at all with out a jump. The Battery is good and i had the alternator checked and it was fine. After i get a boost the car would run fine for a couple of minutes the the lights dim the car stalls as if the alternator was bad. Do you know anything else the causes this problem.
thanks for the help
Lee
Overkill Fetish Freak
I would first check the charging fuse located in the engine bay fuse box. If your Battery and Alt are fine then I would make sure your cables are clean and check to see if the starter power wire is connected properly and clean as well.
I was having the same problem. I replaced the battery and the alternator and everything is fine.
How do you know that both of them are good? My problem was that I got a new battery and it turned out to be bad. Then it caused my alternator to break.
