1 - 12 of 12 Posts
I found balled up insulation in my trunk Monday, indicative of a mouse. I pulled the read seats, emptied the trunk, looked under the carpet best I could and found nothing. I cleaned up and set a mouse trap, this morning the trap is missing. I put my PC bag & lunch box in the trunk every morning and noticed it's gone. I dug around some moving things and it wasn't under any of my stuff. I suspect the trap is between the rear seats and trunk where it dips under the seats, but couldn't crawl around the trunk this morning. I'll try to do that tonight. My biggest concern is how'd it get in and how do I keep any more out?
Where are some entry points I should check?
Have you seen my thread from last year and all the fun I had with mice?
The bastards can pretty much get in anywhere. My guess the trap might be under the front seats or the carpet itself. The big nesting spots I found were in the rear quarters in the speaker area. I gutted the whole interior and caught quite a few before I put it all back together.
Bought a Car Jacket bag for it, it's been in there since early November.
I can recommend these type mousetraps; they work really well.
  • Like
Reactions: Lenise
They were getting in through the oval holes on the backside of the rocker panels toward the rear on my car. Plugged those up and haven't seen any evidence of them since.you'll have to jack the car up and crawl underneath to see them. Mike
This is the first time this has ever happened to me. I did find the trap with the mouse, behind the rear seats where the trunk floor goes down under the seats. I plan on getting under the car tomorrow to check things out. I'll look over your posts Rodeo Joe. This is my daily driver, she did sit for about a week while I was traveling, but other than that she moves about every day.
I left a mouse trap in the trunk just in case. There has been no evidence, nothing chewed up, but this morning there was one in the trap.
I had pulled out the rear seat, trunk carpet and pulled back the rear side plastic pieces to look around. I didn't see any other insulation tore up then. I also couldn't find those holes Rodeo Joe was referring to in the other thread. I need to look harder now.
Mike, what did you plug the holes with?
Pull your rear speakers out and any insulation and take a look inside and down towards the back. I'm told the holes are there for the sunroof drains, not sure if your's has a sunroof or not.
Spent the majority of Sat cleaning out the car. Found the rear drain holes and plugged them. This one does not have a moonroof, but my previous one that I scrapped out did. I believe there were drain tubes at the front and back. Can anyone confirm that and where are those front holes?
I reluctantly removed the front seats and glad I did. That little bugger was nesting along the wire harness that runs the length of the passenger side door. I did find slight wire damage, can anyone tell me off hand what the damaged wires are for in the attach pic?
Pink/ green twisted with pink/ yellow and pink/ blue twisted with brown/ pink.
38062
Twisted like that? Down the passenger side?
Those are the colors some years used for the speaker wiring. See the attached PDF for the wiring off a 1994 with AM/FM radio.
1994 Cougar XR7 DOHC/5-Speed
Yep speaker wires.
The front drain holes for the moonroof tubes are in the same spot on the top of the rocker but behind the kick panels. The likelihood of any varmint getting to those ones is extremely slim, unlike the rear that has rather large unobstructed access points to the inner rocker from underneath, the front is fully enclosed and the rockers filled with foam preventing access from the back. It’s actually a horrible design because the drains don’t really work up front, most MN12s I look at the foam covers the tiny half moon holes water is supposed to drain from up there
Twisted in pairs like that I figured speakers, was hoping it wasn’t something else. I forgot to say it’s a 96 cougar. glad to know the front ones are plugged up. I miss the moonroof at times, but those drain holes just seem to cause rust.
Thanks for all your help, the speakers will eventually have new wires, but first a brake upgrade.
1 - 12 of 12 Posts
