ever since i put in a kenwood deck about a month and 1/2 ago my turn signals would flash like hella fast, but it did it once in a blue moon back then so i didn't mind it much i'd just switch the turn signal off then back on and it would work fine. but in the past few days it has become a major problem, almost every time i use the turn signals it flashes fast like that and switching them off then back on doesn't seem to help. i'm sure it's the deck because when i turn it off they signals work fine... so w/e it is i'm looking for some help, i would get back in there and check the wires but it's kind of a pain in the *** to pull the deck out so i was hoping to get some ideas on what the problem is before i go to the trouble of pulling the deck out. thanks ahead of time for all the replies.
They computer makes the blinkers blink fast when it believesthey are not working. It detects this by whats coming from the negative wire offthe bulb. I think its pretty sensitive to amperage, but i dont think it should have nething to do with the HU. I would try replacing the bulbs. Maybe others will have better ideas than me.
also....they blink fast because there isnt enough resitance somewhere...maybe some kind of light is out that you dunno about...
but changing the bulbs is a step...
