The signal the Idle Air Control on the side of the throttle body isn't sending a good signal back to the ecm. It could be due to a bad IAC or possibly a loose connection.
Well I just replaced the IAC so it must be a bad connection.
Any one know what the voltage should read for the IAC wires to the PCM should be to check if the the wires are bad?
The Band, not the Disease!
P1506 - Idle Air Control System Overspeed. Hmm, did u look to see if the 2 air passages where the IAC valve connects to are blocked in any way? Also did u get a new gasket?
Where the AED manifold is...the IAC is tucked under pretty good, but I know my air tube connection is ok. Yes new gasket also.
ahhhhh ok i didn't know you had the AED. Im not to familiar with the supercharger and intake manifold setup, but I would imagine it being tucked away.. just like the 94 - 95 4.6L manifold =P
