Resident Line Creator
Quick question. Not too sure if its anything to worry about or if its just normal. Is it normal for the CEL light to come on when you are starting the car? It comes on for a few seconds and then shuts off once the car is started. Just want to make sure if it means anything or not. Thanks.
If it comes on at the same time all the other lights come on then its just a system check and to let you know that the lights are indeed working. If its staying on after you've started driving, then you've got a code.
