1 - 2 of 2 Posts
Sale! Sale! Sale!
Here is your chance to be BrainCoated for less! For a limited time I’m offering 2000* Ceramic coated manifolds at sale prices. They are available in 3 colors, Black, Cast Iron Gray & Aluminum. (your existing manifolds are returned as cores).
For stock normally aspirated cars, the basic coating package is generally enough as the engine flow requirements are easily handled by the stock manifold but the coating offers a small performance bump and can significantly drop the under hood temperatures.
For a 4.6 with 'enhancements' (cams, small power adders and the like) you will want to go the ported route. Each runner, elbow and collector is enlarged. This is not ‘clean up’ porting so commonly seen elsewhere but real machine work. This is enough to comfortably accommodate ~325hp and again dramatically lowers under hood temps.
The 'severe' ported manifold option is normally used for power adder equipped cars. It can handle over 450hp (each manifold looses over 1lb of material from the inside.) This is an option needed only for very high output engines.
1) Basic manifold coating option - coated inside and out $155.00 (shipped)
2) Ported manifolds coated inside and out $210.00 (shipped)
3) 'Severe' ported manifolds coated inside and out $275.00 (shipped)
(for a polished cermachrome finish add $85)
(special sale pricing is available for other types of manifolds and headers, please pm or email for information)
Chapter Director Coordinator
this special still good?
1 - 2 of 2 Posts
