How can ask to ford for the gears to my tbird? i want use the 3.73, but, want more i need? and, how can i change to get traction on the twice rear tires?
just tell them you want the FRPP 8.8 inch IRS 3.73 pumpkin (it has trac-lok). You will get an entire pumpkin shipped to you. you can then swap out the pumpkins yourself.
Gears cost $200, and install (this is one thing you can't do yourself) is $300-$400 plus the cost of the Trac-lok assembly while the FRPP unit is around $600.
the only special issue is that your rear end comes a different size stock, which comes with different half shafts. those wont bolt up to a 8.8" rear, which is what the FRPP is.
you're looking at more than just what appears on the surface
