I have a few questions for you guys, your opinions matter.
What I have is a bone stock 1990 351W long block. What I am doing is doing a cheap budget turbo build.
I will be using a Mega-Squirt as the standalone. I have a Garrett A/R .70 Turbo.
For the intercooler, do you think I am better off going with a Air-to-air or a Water-to-Air set up?
What I am doing is dropping the 351W into the bird, adding a nice set of heads, cam, Trick-Flow upper intake manifold and building the turbo around that. The motor will be stock for this summer and I will not push alot of boost. Then once she breaks or i decide i want to push it, I will fully build the motor using the best of the best pats available. Sounds dumb, but that's my plan for the motor, I wont change my mind.
Also, I have the 5.0L MN12 motor mounts and I am using my AOD. Which oil pan will give me the least to no problems with the K-Member?
Thanks for looking and thanks for the help.
Jean
Jean
