Pawn Shop Pro
found oil on the walls of the spark plug hole and Im no the brightest crayon in the box but im pretty sure there's not suppose to be oil above the spark plug. The ones on the driver side were all oil filled and the ones on the passenger side were all dry. And I just changed my oil the day before so all the oil inside the holes was clean. I dunno if it's the rings or the valve seals or what because when I accelerate hard I get a cloud of blue smoke.
It is nice
maybe your valve cover is leaking slightly look and feel around it
It is nice
didnt read part about exaust fumes it is probably rings as bad93 said, or clogged pcv valve
Well this has nothing to do with his problem but heres my question. I am pretty sure I'm going to need some new plugs soon so what should I get? I'd like the triple prong plugs because I hear they give better response, but my friend insists that I should go for 2 prongers so I'd like some outside advice. Thanks.
