Im finally getting around to changing the leaking head gasket in the bird and i was just looking for any advice just make it any easier. I wish i had the money for some pi heads but moneys a little tight right now.
leave the engine in the car, unbolt the powersteering pump with a 10mm 12 point box wrench, remember to unbolt the trans dipstick from the back of the passenger side head, leave the exhaust manifolds attached to the heads but disconnect them from the rest of the exhaust, don't mess with the ac compressor at all, remove the 4 front bolts on the oil pan while removing the front cover, you'll need a 15mm deep socket and 18mm deep socket
