1 - 2 of 2 Posts
I have A 89 lx 3.8 will not charge replaced alt brushes&regulator found burnt fuse link at starter relay is this cause of no charge thank 4 input
if you have a short in the system anywhere in the battery circuit, it will naturally go to the least resistance path.... a ground. so if you found a bad fuse change it and go from there.
1 - 2 of 2 Posts
