1 - 11 of 11 Posts
ran dyno for first time today not to impressed with horsepower but good enogh with toruque heres the results
Run 1
Torque 191.1
Hp 120.8
Run 2
Torque 207.5
Hp 118.6
any info on hp gains would appreciated. In process of gasket matching and polishing the intake manifolds not sure what to do about throttle body. saw the greene machine offers boring and halfshafting but thinking about getting the 60mm on instead. Will be getting my injet tech chip reburned by ford chip when get closer to installation. how does that sound for chance. i have the actual dyno sheet scanned can email it to you if want to see the curves.
Ryan
Your torque is fine (around 200 for your mods), but I would put you at around 130rwhp with your mods. A Stock 97' Dynoed 119rwhp (145hp stock)
yeah your a little low...i seen a stock 94/95 tbird with dynomax exhaust and a jerry tune make 122rwhp...absolutely nothing was done to motor...not even kn filter
runs lean when get into the gas, around 2800 to 3000 then stays there i think my o2 are shot because a/f gauge doesnt even have a reading until car has been running for about 20 mins think might be my prob
why are ryans hp numbers so low? i thought 93s have 140 hp stock?? or is the 140 rated at the flywheel? did he lose hp? educate me, guys. thanks.
mike
140 at the flywheel...he made 120 at the wheels...power loss through drive train...is that in inject tech chip you have by Jerry? you may have a lean spot at that 2800-3000 rpm range but i doubt it and if it runs fine after 3000 it wouldnt have an effect on the max hp because your making that at around 5000...that lean spot that you think you are feeling is probably the tq converter locking up...i have a fordchip i get the same thing...Jerry now tunes fordchip...how are your plugs?
got the chip directly form jerry i only live about 40 mins from him. the plugs were a little white but nothing bad. the lean condition is from the a/f gauge i have but i think it is bad was the same reading before the chip and maf install
those a/f gauges are good for nothing...except asthetics...you should have gotten a real a/f read out while you were on the dyno
I dynoed a year ago Sept, 3 pulls and the HP figures seem fine but the torque was off:
HP=120.5 Torque=152.7
HP=120.4 Torque= 168.8
HP=122.7 Torque=193.0
The only mods at the time was a Dynomax cat back and a K&N panel filter. I've since added a CustomChip and underdrives. I'd like to do it again to compare.
Damn, I gotta bug my tech to give me the dyno sheet for my car so I can post it.....
Beautiful spike at 2500 R.P.M. when my boost hits!!!! :cool:
And no, it's not a 3.8 S.C.
turbo???????????
1 - 11 of 11 Posts
