Thanks. I'll try and do that this weekend if I've got time.
Send a PM to Justin on FBWhere can I buy them
Well, like @Zep5.0 said. I like living on the wild side!All that wont stop your car without brake pads .. 😂
If youre going to spend big .. Go big. And yes its worth the difference.I guess the real question then is, is having 1 more inch of bite on a caliper worth $185?
Even with my suspension build, I have new (5*108) hubs for front and rear.Nevermind. I see you have new hubs planned. Make sure your lugnuts will fit the new hub studs threading.
I'm not going to be getting wheels until I do my brake upgrade. That's the next phase of plans for my car. I purchased new 5*108 hubs to have a fresh set on all 4 corners for now. With the brake upgrade, I'll be having 5*114 hubs on all 4 corners.Why stay 5x108? If you’re doing a big brake upgrade you may as well hub swap
I wouldn't replace the hubs until you do the brakes. The originals should be fine.I purchased new 5*108 hubs to have a fresh set on all 4 corners for now.
