what is this ---silencer--- i hear about removen please explain im new to the 4.6 world as well thanksother than removing the silencer.... erm... i did have a thread in general tech.. the best free mods.. had some good posts.. just do a search for it. that should elp you out.
I was checking that last sunday, I saw the 3 screws holding down that piece of plastic, I didn't think it was that restrictive so I left it in place and also left it there because it seems that if I remove it, the air box won't be held in place.remove your air box and panel filter and you will find 3 screws holding a moderate-huge piece of plastic in place under the fenderwell... the silencer is that piece, you don't want it or need it, so get rid of it, you'll probably like how it sounds without it as well.
I don't have a pic of it...it went in the garbage as soon as I pulled it out. It's a U shaped tube...mainly to keep water out of the intake and knock down the intake air noise (when you pull it off it should have a faint whistle to it and make engine sound a little more throaty), which its main purpose.I was checking that last sunday, I saw the 3 screws holding down that piece of plastic, I didn't think it was that restrictive so I left it in place and also left it there because it seems that if I remove it, the air box won't be held in place.
Any of you guys have a complete pic of the silencer, cause I think mine is broken, maybe that's why I dont think is that restrictive (unlike the one that was in my Ranger).
J-mod ~ $100J-mod, new "custom" torque converter from dirtyd0g, gears and tune. . . .this should set you back about $800-$900. After these mods your driveline is better built to withstand the engine mods you can make next for higher dollars!![]()
