So my check engine light is on and it is the typicall egr problem. I can get it to go off by clearing the code but comes back on. I really dont want to change it cause of where it is. I need to get the car smogged and the last time i did it the damn light came on in the middle of the test. So here is my idea ( temporary idea.) I was thinking of swaping the wire for the check gauges light and the check engine light. When the key is on engine off they are both on. After i clear the code and start the engine they both go off about the same time. I just need to know what wires and if it will work ! any ideas ??
ahhh thats a great idea. Might have to try that one if my light ever comes on.
ok mickey moused the wires it works but sometimes the check gauge circuit wont activate, my luck i will take it to the smog check and it wont come on like it supposed to then shut off when engine is running. I am going to try and use the battery light which comes on every time like it should.
