1 - 2 of 2 Posts
what a crazy day! My old man was right. It just had to be reset. I messed around with the air intake and it didnt work. If you disconnect the positivie cable of the battery (u do the negative first of course) and once u put it back together, the light will be reset, therefore off. it worked! im so glad its better now.
-Andrew-
uhhh, problem not solved.. that just reset it until you drive around for a while and the same problem will get read.
i had my check engine light on for a while, disconnectd the battery when i put a new alternator in, and the light was off when i reconnected the battery... well, about 2 days later after some driving, it came back on, because the problem still existed (it's O2 sensors.. i've all ready had my code read). it just took 2 days of driving for the computer to realize that it was constantly getting bad info coming into it, so it threw the code.
1 - 2 of 2 Posts
