MaleWhore
well did a search and only found one thing...that kinda related so i decided to start one...i went to pull the codes on the CE light and i got 2...both of them P0156...as i remember something about cats...i have exhaust with no cats so i put MILs on the second pair...now how do i get rid of the codes...sometimes the CE light comes off, then comes back on and so on...still same code
You could have a bad O2 sensor. I had a similar problem where the CE would come on and off. I knew someone with a computer so they checked it out and it ended up to be a bad o2 sensor. THese cars have two sensors so i changed both of them. CE light hasn't come on in 2 years. Hope this helps.
MaleWhore
later models have 4 o2's so what im thinking is that one of the 2 ones i have left, one of them might be bad
