1 - 2 of 2 Posts
Well, I found a rear disc donor car for free. Figured I would rebuild the rear while in there. I'm also changing the pumpkin. I searched and found a rear end rebuild list. Could you folks look it over and see if I need anything else. I'm confused on the LCA. Does it have "at the frame" bushing that can be replaced? What about the 2 lower attachment points for the spindle?
I have the rear sway bar stuff in poly, Axle nuts, front (poly) and rear (OEM) pumkin isolators, new cir-clips and seals.
Need to get?
Rear Suspension:
REAR COMPENSATOR LINK K8594 x2
Understand this one.
Upper Control ARM TO FRAME K8562 x2
Seems self-explanatory
Upper Control Arm ARM TO KNUCKLE K8588 x2
where top of spindle mounts to uca.
Lower Control Arm Kit K8658 x2
Confused on this one. Does it have all the bushings for the LCA (at the frame and at the spindle)? I looked it up on Rockauto but, the pic was horrible. Basically I need to know what to get for the LCA both at the frame and the 2 places it connects to the spindle.
Appreciate all the help,
Rob
Discussion Starter #2
ttt
Rob
1 - 2 of 2 Posts
