1 - 17 of 17 Posts
drag-aholic
I want to have the plentum,thermostat housing and maybe the valve covers chrome plated. I know its going to be pricey, but here is the question. When they chrome the plentum and the other parts will they plug the holes so they don't plate the inside. I know they dip for this process in different tanks. I don't want to worry about plating flaking off and ending up in the engine. anyone know?
If you're talking about the upper intake, why not just polish it? It's aluminum.
As far as chroming goes, I have no idea. I try to stay away from the stuff.
-Rod
drag-aholic
yeah, the portion that has the 3.8 on it. thats aluminum? Wow looks like a lot of work to get it as shiny as i would want without the proper tools. thanks
Dim Bulb
If you're talking about what I'm thinking, you could alwasy try sand or bead blasting the part before you do the work. Try talking to big mike, I think he's done work on his upper
Full Metal
plastic? if they are similar to my 92's valve covers they are aluminum or magnesium covers with a special coating. IIRC.
i got a 94, and when i went to paint them it was a hard plastic type material. maybe im wrong and it has a really thick coating of some sort, but when i stripped them it was plastic.
Full Metal
got pics?
odd... all 3 sets I have seen and sandblasted are metal. They look and feel plastic, but they are infact metal.
the valve covers you can't. they're plastic. buy some valve cover from jegs
I have yet to run across a set of plastic 3.8L valvecovers. And I've been through a lot of them, from 89 all the way to 2000 model 3.8L engines, NA's, SC's, and splitports.
-Rod
Why not powder coat them? If they are metal and there are no rubber/plastic bushings then powder coating will work/look great. And you don't have to worry about the insides.
the valvecovers are magnesium/aluminum alloy. they'll polish, but they'll never keep a shine.
powdercoating is the way to go. And in fact, you can even do chrome powdercoating, it'll be much more durable, you can tape off whatever you dont want powdercoated, and it'll also be more durable than chroming would be.
-Thomas
The latest in powder coating is high temp powders. I think you could even powder coat an exhaust manifold but I'm not sure.
they do, and its much cheaper than ceramic coating, though Im not sure it'll retain heat like ceramic coating. But they only make the high temp stuff in flat colors.
1 - 17 of 17 Posts
