1 - 20 of 90 Posts
Spent the week working on the car and took the opportunity to pull out some of my extra parts. There will be more once I get to the shed.
My PM box fills up fast. Please use the link to email me about any parts you are interested in. It makes it easier to track conversations and allows me to reply more quickly.
Foot operated parking brake pedal assembly and cables, OEM with no rust, removed from a California car with 50k – Make offer on all or part
MN12 4.6 Oil Dip Stick w/ Tube - SOLD
Mark VIII Oil Dip Stick w/ Tube - SOLD
Lincoln Aviator Oil Dip Stick w/ Tube – Make offer
Trans Dip Stick w/Tube Unknown Vehicle - $10
96-98 SN95 4.6 Valley Coolant Tube – Make Offer
Mark VIII Valley Coolant Tube - SOLD
96-? SN95 4.6 EGR Tube – Make Offer
1st Gen Mark VIII EGR Tube – Make Offer
Unknown Alternator Bracket – Make Offer (free?)
94-97 4.6 Transmission Lines, 50k and no rust, not sure if this fits other engines or Mark VIII - SOLD
‘93+ Front Spindles for ABS (Local Pickup) - SOLD
‘92+ Rear Disc Calipers, lines, cables, and rotors - $20
30lb Injectors - SOLD
39lb Cobra Injectors (EV6) - SOLD
19lb Injectors, unsure of mileage, worked when removed but have some broken pintel caps - $20
19lb Injectors, 34k and worked when removed - $40
Fold down rear seat braces w/ hardware - SOLD
Stock 4.6 fuel pump, only 50k and removed for larger pump – Make offer
Comp Cams Vacuum Canister , New in box – Make offer
4R70 Trans Pan – Make Offer
Tensioner (Qty. 2) – Make offer 1 SOLD
MN12 4.6 alternator - $40
SN95 4.6 Alternator - $40
Aviator 4V 4.6 Alternator - $40
Rebuilt Starter - SOLD
OEM Starter, some rust – Make offer
96-07 MN12 4.6 throttle cable (Good for 94-95 PI swap) - SOLD
SN95 4.6 EVR Solenoid Bracket with solenoid – Make offer
Coil brackets, drivers side has been painted black – Make offer
EGR valve – Make offer
Radiator top brackets – Make offer
96-97 4.6 MN12 thermostat housing (Qty. 2) - $5/ea
96-97 4.6 alternator bracket (Good for 94/95 PI swap, 1 remaining) - $10/ea
Transmission inspection plates (Qty. 3) – Make offer
4.6 water pump pulleys, long style (Qty. 3) – Make Offer
Idler pulley – SOLD
MN12/FN10 4.6 oil filter/coolant adapter – Make offer
94/95 Gray passenger side dash vents, color may be slightly different from 96/97 - $10/pair
94-97 Multi-function switch - $20
94-97 Cruise control switches – SOLD
94/95 SC manual shifter boot in OK shape - SOLD
94/95 SC Fog light switch (Qty. 2) - $20/ea
94/95 SC Fog light switch button w/ good print – Make offer
94/95 Firm ride switch - $10
Interior Fuse Box Cover - $5
94-97 automatic climate control unit - $20
94-96 door lenses - $10/pair
97 door lenses (all red, one is missing a tab but still retains OK) - $10/pair
94-97 console arm rest (Qty. 2) - $20/ea
Ignition cylinder with key (rare TCCoA key chain included) - $20/shipped in U.S.
94-97 Gray Under Column Panel, two missing clips - $10
97 gage cluster, shows 154k, missing the fuel/temp face - $20
94-97 Black Column Trim, good condition - $10
94-97 Shifter position indicator, needs cleaning but isn't completely faded - $10
94/95 SC rear speaker covers for gray base interior - $20
94/95 rear speaker covers for gray cloth interior - $20/pair
Gray drivers side kick panel - $10
97 gage cluster, shows 177k - $30
94-97 Thunderbird LX drivers airbag, (not sure I can ship this) – Make offer
Rear view mirror - $10
94+ headlight switch – SOLD
96/97 Gray Lower Seat Trim, very nice, from car with 50k - SOLD
94/95 Gray Lower Seat Trim, incomplete set - $15/set
97 Cupholder insert (Qty. 3)- $10
Black Thunderbird third brake light cover - $5
94-97 automatic shifter mechanism and cable very nice 50k - $40
97 console with 50k (includes near perfect top, arm rest, and base with tube; the wiring, trunk button and traction button have been removed) - SOLD
Black Mark VIII Seat Belts - $30
96/97 Gray Seat Belts, very nice, from car with 50k - SOLD
92-95 LX passenger side taillight, good condition, 1/3 LEDs do not light up - $15
92-95 LX taillights, all LEDs light up, passenger side has gold bird and some scratches - $20/passenger SOLD/drivers
92-95 LX corner lights, slight damage to bottom edge of passenger side - $25/drivers $20/passenger
Side mirrors for cars without chrome trim (Driver Qty. 3, Passenger Qty. 2) - $10/side Venetian blue pair SOLD
02-04 Mustang GT air box, 80mm MAF, screen, and MAF pigtail (will come with un-modified snorkel) - SOLD
02-04 Mustang GT air box and screen - $20
C&L Plenum with 70mm Ford Throttle Body - SOLD
70mm Ford throttle body - $80
C&L intake tube with MAF (looks like 96 sensor in 80mm housing) and divider for Mustang - SOLD
Stock air box with 96/97 MAF, 50k - $20
96/97 4.6 intake tube, 50k - SOLD
02-04 Mustang intake tube (good for GT air box with 80mm MAF) - SOLD
97-98 Mark VII Intake Tube (Qty. 2) – Make offer 1 SOLD
NPI intake manifold w/ aluminum crossover, low mileage (I picked this up from another member as a spare for my Cougar but never needed it before I sold the car) - SOLD
Mark VIII oil pan and pickup, nice but has a hole for supercharger oil return – SOLD
Battery base and hold down, used but is a replacement with low miles - $10
Starter/battery wiring harness (Removed from a 96 4.6, battery clamps have been replaced) – SOLD
SN95 oil pan pick up – Make offer
MN12 4.6 oil pan pick up – Make offer
Steering rag joints, OEM less than 50k, long discontinued from Ford (Qty. 2) – $10/ea
CCRM - SOLD
ARC Covers ( Qty. 2 Pairs) – $20/Pair with hole, Make offer on pair with hole in one side
96/97 fuel rails, lines have been replaced - SOLD
94/95 Front Plate Bracket - $10
94-97 power antenna, works but mast is broken off - $10
4.6/SC Eibach springs – SOLD
Mafia MAF range extender - $60/ shipped in U.S.
03/04 Cobra radiator, fan, and brackets - $180
B&M Trans Cooler (I will include for free if purchasing radiator above)- SOLD
JL (RIB) front shock tower brace - SOLD
Homemade rear shock tower brace - SOLD
Mark VIII door sill trim w/ brushed stainless strip (Nice upgrade for MN12) - SOLD
Window felts - SOLD
Pictures pending:
Window Runs for cars without chrome trim, good condition, only one small area of bubbling behind drivers mirror which is difficult to see when on the car (Local Sale Only) - $20/Drivers, $30/Passenger, $40/Set Driver side SOLD
94/95 Thunderbird OEM header panel (Local Sale Only) - $20
All prices are or best offer. the more you buy, the more generous I will be with negotiations. Shipping and Paypal fees are additional. Additional pictures and information are available on request.
Bryan
I may want the fold down rear seat brackets. Not sure if the seat I just bought comes with them or not. Will know later this week. Thanks!
Bryan, I'm in for the:
02-04 Mustang GT air box, 80mm MAF, screen, and MAF pigtail (will come with un-modified snorkel) - $60
And the GT tube that matches:
02-04 Mustang intake tube (good for GT air box with 80mm MAF) - $20
Send me a total with shipping and fees, and your paypal addy, and I'll send cash. :)
Let me know your zip and if it will be a residential or commercial address for shipping.
Bryan
Bryan
Residential, and 37748. :)
They won't let anyone ship to work ever since someone ordered a bumper for a 56 chevy, and it sat on the dock for two days...
No, not me, lol.
I will not need the L brackets. My new seats are not fold downs.
The L brackets are great for stiffening up the rear quarter panels.
I have a rear shock tower brace made of rectangular tubing. I think it's pretty stiff already. :)
Hey Bryan, how's the paint look on the drivers/pass. mirrors painted in the Venetian Blue? If they're in good shape I'll take them both. Will save painting new ones since its the same color as my bird. Shipping would be to 63369.
PM/Email sent!! In order of desperate need, strut tower brace ,various air inatke parts{details in EMAIL} and lastly black center console trim and arm rest top
Email sent!
Discussion Starter #15 (Edited)
No, not me, lol.
Sending an email.
Interested in the black mark 8 seat belts. Can you give details? What is your email?
I replied to your email.
The paint looks good and the black trim is in good shape. There are some light scratches with a small scuff on the passenger side which might rub out.
I will find a box and get a quote to you tomorrow
I didn't get an email.
Email sent!
I think I have replied to everyone, let me know if I missed you.
I added a couple pictures to the first post.
The springs, 39lb injectors, and seat brackets are pending payment.
Bryan
Well I sent a message through tapatalk. Let me know if it goes through. Otherwise. The front tower brace ,black console trim and the arm rest part
Sent from my SM-G900V using Tapatalk
PayPal sent for the items that we discussed.
Discussion Starter #18
All PMs and emails have been replied to.
Eibachs, seat brackets, and 39lb injectors are sold.
Bryan
I didn't hear back...
:grin2:
Discussion Starter #20
:grin2:
I sent you an email through the forum but think the forum is having issues with that. Will resend in a few by PM.
1 - 20 of 90 Posts
