1 - 11 of 11 Posts
Random parts, see pictures below, make an offer on anything. I also have:
-a set of factory springs (approx 50k miles)
-Ford lower control arms, need new ball joints (~50k miles)
-Outter tie rod ends (unknown, not original, greasable)
-Inner tie rods (off a rebuilt rack ~ 30k miles)
-Front spindles, wheel bearing/ hub assy less than 50k, Timken bearings.
-The Alpine is a CDA-7839 w/ headphone jack
-The middle arm rest is covered in leather.
What is the wiring harness in this pic?
That would be the trunk lid, with the wing 3rd brake light. The short ones are the plugs for the taillights cut off from the car side.
A few questions:
Would the alpine radio fit a 1996 cougar(plug and play)?
Is that dash vent grey and for the right of the glove box?
What's the condition of the EGR? What engine was it from?
Thanks!
A few questions:
-you would need a wire harness to plug into the factory wiring, like this: http://a.co/hhcN203 otherwise it should fit.
-It's 97 tan
-EGR is good, never had an issue with it. Was off a stock 4.6L with about 120K.
1 - 11 of 11 Posts
