Ok im pretty sure i going to need a clock spring. My symptoms are no cruise control, no horn ( unless someone cuts me off) air bag pulses a code 32. This might seem unrelated but my turn signal stalk stays either left or right no matter what position the wheel was it, and i have to bring it back myself or i signal forever. But my question is the clock spring a dealer only item? if so would it be worth it to buy it used? I feel really unsafe knowing my bag wont go off if i get into a wreck, even worse becuase my seatbelt wont lock up, so i think :cbones:. Is there anyway i can tell if the clock spring is bad? I have a few days off till i go back to work, and if i can find these parts in a yard (seatbelt and clock spring) for cheap then my 45 mile drive to work will be alot less nerve wrecking TIA
