1 - 12 of 12 Posts
Chapter Director Coordinator
Hey guys
i know we all have it, we shift from park into reverse or drive and hear the tranny clunk.. i am also one of the lucky peeps to have something clunk when i first take off for the day..
yesterday, however was unique. it clunked not once, but 3 times......... i gunned it a bit around the corner cuz i felt like it and when it shifted into second.. i heard a clunk... it did it again about 10min later, i was crossing the main road, has a little 25-30deg hill, then goes down at about 35deg into a turn.. as i just cleared the top it went into second and clunked again.
i keep pushing the date to do the jmod and get me irs bushings put on and new u-joints, cuz i may be getting $2500-3500, and that would mean... FRPP rear and MMX driveshaft.. so it would be like.. fully refreshed driveline..
Is it the u-joints clunking or something internal in the tranny? btw, i am firmly convinced at least 1 of the 1-2 springs are broken.. it doesn't shift superfirm (no kit), but it will go a lot quicker than say, the 3-4...
JD
Pedal Faster
MY clunk is u-joints... I'd always heard a little clunk on hard shifts, then I rode in the back seat while someone else drove it... BIG clunk! New u-joint time for me, guess it'll get done over Christmas break...
Might be your torque converter unlocking/locking.
on the 1-2 shift?? then again, i usually do feel the clunk somewhere under the floorboard area... but i can usually feel a small bump i run over w/ the back tire....
jamesD said:
Hey guys
I have the EXACT problem, but it's most noticeable on the first 3-4 shift of the day(sometimes 2-3 too), and when it's cold. As I am having the clunk when shifting from P to R or D, and have a drive line vibe, I'm pretty sure that it's my worn out IRS bushings(they are flaking and have vertical play, already had them inspected) AND the u-joints.
Does your also clunk when leting off the gas(with lerch), and again when stepping on the gas, with a little delay in acceleration+clunk? mine does that and most people think it's a sign that it's the u-joints.
i know sometimes if i let off the gas after doin like 60, slow down to around 40-50mph, then pop the gas real quick, i guess the sudden amount of torque or whatever will make something clunk/shudder/pull real hard.. it hasn't clunked on the 3-4shift... that's a band anyway no?? my irs bushings aren't new, but there is no play, same w/ the tranny mount. i will swap them out when i do the "mod"
JD
Check your TC/Flex Plate bolts...
LMAO
those bolts were fine at the time.. heh
lots of cars do it.. damn lockup schedule
Im having the same problem...
is this something to worry about, cuz I've been trying to track it down after I stalled my track-loc rear end....
its coming from the tranny... the ujoints are new... IRS bushings are brand new....
got me worried cuz it doesnt sound healthy.
MG
check your suspension.. turns out, one of the clunks was the fact my rear sway bar end link bushings were not there anymore.. heh.. metal clunking metal
Eleventeenth Gear Poster
MG
I get the occasional clunk when putting the car into reverse or drive and I also get a clunk while cruising like James mentioned in the 6th post in this thread. I was thinking it had to do with my TC and/or the TC lockup schedule, but Kentwood suggested checking the tailshaft bushing in this thread that I started on the subject. I havent gotten around to checking it out though.
I was origionally thinking it was a u-joint problem, but I changed them and the problem remains. It feels like some thing is loose in the drive line, I've gone over every bushing I can see and get to without taking the car apart and I dont see a problem anywhere. That leads me to believe the problem is within the trans or rear end.
1 - 12 of 12 Posts
