Okay...I just got my lower control arms and new tie rods...and my passanger side upper control arm just got a new one my drivers side one needs replaced im am in the process of replacing it....and it makes a lil noise but its not the noise that im talking about..so there shouldnt be a problem with them..when im going down the road lets say im doing like 45mph i can hear the loud clunking noise it almsot feels like it is coming out from under my feet i took it the repair shop and the guy said that it was my rear diffrential the gears are getting bad and when it gets some torque it make the driveshaft slip a bit and it makes the clunking noise throghout the car.
???HELP???
Discussion Starter #2
?anyone
Two of my birds have made strange clunking noises, both of them were traced down to the exhaust. One of them was too close to the left rear suspension and was rubbing where the A Arm bolts too, made strange clunking sounds. The other one was laying on the brace that runs right in front of the pumpkin. It would only clunk when I took off, as then engine and trans would torque it up off the brace and then lay it back down.
To put it short, i would check the exhaust also. A used pumpkin with good gears is fairly cheap and not hard to install if that turns out to be your problem. Good luck.
02 Explorer Pioneer
Does it corespond to bumps in the road or just steady driving? If bumps take a look at you rear swaybar endlinks
yes it does...it coresponds alot more to the bumps in the road..and just steady driving but mostly bumps in the road. but it still puzzles me why i am feeling this up towards the front insted of the back?? or is it just vibrating throughout the car?
My exhaust rub was vibrating through the whole car, worth checking out. 10 minutes on a lift or just crawl under the car and see if its touching anything.
they had it on the lift over a tirespluss I was under there with the guy...but i wasnt looking at the exhaust maybe ill get under it and take a look at it later.
02 Explorer Pioneer
If it's the sway bar endlink bushing it will be real obvious
Thanks for the heads up Palm Guy :eek:
