is it a direct swap to go from a 95 cluster to a 97 cluster?
S sniper77 · Registered Joined Apr 10, 2005 · 258 Posts Discussion Starter · #1 · Jan 28, 2007 Only show this user is it a direct swap to go from a 95 cluster to a 97 cluster?
M MadMikeyL · Super Moderator Joined May 22, 2003 · 8,287 Posts #2 · Jan 28, 2007 Only show this user No.
95xbird · Registered Joined Apr 20, 2006 · 4,407 Posts #3 · Jan 28, 2007 Only show this user MadMikeyL said: No. Click to expand... :zwthstpd:
S sniper77 · Registered Joined Apr 10, 2005 · 258 Posts Discussion Starter · #4 · Jan 28, 2007 Only show this user damn.
master486 · Newbie Joined Jun 12, 2006 · 5,650 Posts #5 · Jan 29, 2007 Only show this user There's rewiring involved and the trim panel for the 94-96 clusters isn't the same as 97.
Bigiron383 · Registered Joined Sep 23, 2003 · 382 Posts #6 · Feb 2, 2007 Only show this user Physical Fit So there's a problem with physical Fit? I don't remember seeing anything about that in the past post.
S Southpaw · Registered Joined Jul 20, 2005 · 3,180 Posts #7 · Feb 2, 2007 Only show this user They use different cluster bezels.
Bigiron383 · Registered Joined Sep 23, 2003 · 382 Posts #8 · Feb 2, 2007 Only show this user Problem ? Other than a simple remove and replace is this a problem ?
