1 - 16 of 16 Posts
My clutch fan just went out. The thermal valve went out so it won't kick in when it gets hot. I read that a clutch fan looses 200 rpm a year and should be replaced every four years.
Is there any reason not to switch to a two speed 3.8L fan?
no reason I can think of
Back when I had my 3.8 bird the clutch fan went out. I replaced it with the "Black Magic" Flexalite electric fan. Wow what a difference in fuel mileage and acceleration. I used the model for the 5.0L Mustang "Black Magic". It was a perfect fit. The electric fan reduces the drag and HP loss it takes to turn the mechanical which is how you gain fuel economy and power.
Mechanical fans are still the old stand by and work well, most auto companies are going to electric fans due to confined spaces better fuel economy #s and listing higher power ratings.
Steve 4.6L
yeah, go with the electric all the way, you'll thank yourself. the only catch 22 is if you want to mount a trans cooler or oil cooler on your radiator. you may not be able to. on my car i mounted a oil cooler and just barely was able to make it fit. this would be something to keep in mind if you are doing a J-mod on your trans. you'll have to mount that trans cooler somewhere :)
I need to use my car so I set it up in a temp config and it worked great even while being on the low speed. I'm going to break out the relays and do it right today.
I'm very interested in this. What mods are needed to convert a clutch fan cooling system to electric?
Perch
What are you guys using to turn the fan on (other than a switch)? I had thought about an electric fan, but I hadn't found an auto control setup I like. They were all mounted in front of the thermostat, but it seems to me in the thermostat sticks closed, there could be problems. Dunno :p
I've never been a fan of havng to use a switch in the car to turn on a cooling fan and it looks cheezy so a termostatic switch was the only way. Anything with this much juice going through it need atleast one relay. By the way, your the thermostatic switch is different than a thermostat. It is a temp sensor that closes an electrical connection at a certain temp (use to turn on a relay running the cooling fan), a themostat allows coolant flow above a certain temp. If the thermostat stuck closed it would be the same if you have an electric or mechanical fan, the engine would be isolated from the engine coolant and no amount of airflow over the engine would cool it. Most people have the temp switch in the radiator but mine is on a cooling hose toward the back of the engine.
I dunno why I didn't think about that. Was my dad saying it might be a bad idea. The N/A bird is getting an electric as soon as I can ;)
I don't think you understand how this works. If your thermostat sticks closed the coolant bypasses the radiator, thats its job. The fan and radiator would have no cooling effect on the engine. This is how most japanese and european cars' cooling fans work.
A switch? You're kidding. A thermostatic switch sounds more appealing. Is there a more elegant solution?
Perch
You can't really do any better than a thermostatic switch.
I get exactly what you're talking about. If the thermostat is stuck closed, you're not getting the coolant in the radiator to the engine, so it wouldn't matter how cold it gets.... you're still going to get hot if the fan is or isnt running.
My dad was the one who told me it could be bad if the thermostat stuck closed and I really didn't think too hard on it (he's a mechanic.... but usually diesel, so he's been known to be off when it comes to newer cars).
And I wasn't sure if people actually used a switch for their fans (I'm sure some might) but I'd rather not. In fact I had a setup like what you're talking about at one point, I'll have to see if I can't find it. I don't recall actually installing it.
Discussion Starter #14
Sorry about that, I didn't mean to be condisending. I guess I misenterpreted your post.
Confirmed V6 Nut
My 97 came with an electric fan. An idea might be to take a look in a Haynes manual or a Chilton's to see what is different and upgrade with Ford OEM parts.
Maybe, pm jk89cat or Thomas and see what they say.
1 - 16 of 16 Posts
