I recently received my rear bilsteins and have a silly question:
Q: the upper shock bushings look a bit different between what I received with the Bilsteins for the 99-04 cobra and what came with my motorcraft rear shocks 6 years ago.
From what I recall from bottom to top the original bushing setup looks like this: shock absorber, metal washer, bushing with the pointy end up, shock tower/car body, other bushing, metal washer, nut.
What came with the cobra bushings is as follows:shock absorber, metal washer, donut shaped bushing, shock tower/car body, donut shaped bushing, metal washer, nut.
Q: Did you guys just reuse the bushings from your old shocks or will the two rubber pieces that came with the cobra bilsteins work just fine? I haven't painted my shocks yet (because cheaty racecar) so I haven't test mounted them.
Obviously, I would use the nut that came with the bilsteins but reusing my current motorcraft rear shock bushings seems out of the question (they look beat to hell).
Online, it looks like ford will sell me these bushings for a whopping $80/ea (nearly as much as I paid for the shock absorber). A more realistic purchase would be to buy a tbird rear shock that comes with the right bushing but that still sucks as that means I would then have two extra soft shocks I'll never use: $27/ea
What my tbird came with (see bushings):
KYB Shocks & Struts Shock/Strut GR2 Twin-Tube Ford Thunderbird Cougar Rear Ea | eBay
What the cobra bilsteins came with (see black bits):
