Is the Front and Rear Cobra brake kit from discbrakesrus.com a complete bolt in kit, or is there other parts/machining required? My rotors on my T-bird are warped bad and brakes are the next thing on my to do list. I have thought of getting some good performance rotors and pads for my stock brake system, but I don' think it will yield much of an improvement. I am just wondering if it is worth it to go with the Cobra kit, which is what I am leaning towards now because of the much better calipers and larger rotors. (Stock brakes looking tiny behind the 18's)
the front brake kit it a direct bolt on. When you order the front kit, ask to speak to Jeff and he can machine a groove on the passenger side caliper to clear the banjo block.
i cant speak for the rear kit....
Discussion Starter · #3 ·
Thanks for the reply, does the rear kit come with new calipers as well? I don't think they new rear kit would have much of an effect but I think it would fill out the 18's better pn the rear if it comes with larger rotors.
bump, does anyone know the answer about the rears...
im in need of new brakes and i was wondering the same thing, if they are bolt on or need modification
get with SHADOW on that one. i beleive they modded the kit to be a bolt in.
