Will an 03 Cobra block bolt into a 94's motor mounts? I remember reading something somewhere but now I can't find it that some sort of block will not mount in w/o making new motor mount holes. Also what is the 03 Cobra--Romeo or Windsor? And a 94's? This is probably the question I should have asked... Thanks
The Windsor plant closed, 03's are Romeos. 94's were Romeos also. I don't see what they could have done differently to make your engine mounts not work. Everything external to the block should be the same.
OK Thanks. I was pretty sure that it would fit, but just wanted to double check.
