CEO, WT Club
Thinking about switching to the stang bolt pattern, and I want to do this while I am in there. I believe EECDOC has this kinda setup, is it basically for strength reasons? Does it effect the offset of the rear wheels at all? Any info, or point in the right direction would be appreciated. Thanks.
-Joel
Chapter Director Coordinator
you talkin 31 spline cobra half shafts? they are a tad too long
i dunno about offset fixes, etc though
CEO, WT Club
Yep, thats what I mean. Can the be made to work at all? If they are longer, then that's good, I want to push the hubs out so I can run a different offset wheel. What exactly is Siska's setup?
-Joel
I just talked to Mike about this he bought level 5 axles then got cobra axles had the cobra inner hubs machined and installed them onto the level 5 axles. Don't think this will be a cheap project ranking in around $1500 for the axles.
Alan
CEO, WT Club
I know it wont be cheap, not worried about that at the moment. Do you know if it effects the position of the hub? I want to know if it pushes out the hubs, so I can run wheels with a higher offset.
-Joel
CEO, WT Club
Alright... I'm still confused though, is it located out farther that a stock hub? I have a 10" rim I am thinking about with a 50mm offset...trying to find a way to make it work.
-Joel
I don't believe so I think it's in the same position from what I was told that is why the inner part had to be modified.
Alan
