Geek w/Gearhead Complex
Not real clear on this so I thought I'd ask before I bought one.
this past weekend I was doing a TON of stuff to the car which involved taking all the plastic BS off so of course, I see the throttle body and have to play a bit (pull the cable) and notice something ...it opens one, then the other. So its like one is open 60% and then the other starts opening. So being slightly irritated with it (shouldn't they both open at the same rate?), I'm considering a new one, probably a BBK or maybe a Accufab.
Now my question is one, would it be worth the 300+ bucks for one? Two, should I get one thats a big oval or split (twin 62mm) oooorrrr just leave it alone?
IMHO, no, it's not worth the expense. (And I don’t think they will physically fit on the Gen I intake)
But I've noticed the same thing with the delayed opening, that is the way they are designed. I have a few spare Gen I TB’s laying around and I’ll look to see if there is some way to lock the linkage so they open at the same time.
Also, I don't think a standard Cobra TB will bolt up to the Gen I Mark intake. And I know the throttle cable attachment points are different.
I think the only way to improve the intake systems on the Gen I’s are to go with the Cobra intake swap (but that involves cutting the hood for clearance on a Gen I) and I'm not sure of the benefits.
Keep in mind that your Gen I intake system is better than my Gen II's. :mad: ;)
I'm going to go to the Cobra intake real soon my 97. :thumbsup:
screw that! ...no literally, kenne!
I've considered going to the cobra intake ...just have to find one (complete). I haven't made a total decision on if I'm going for an NA setup or blown...I understand what is needed to go to a 98 cobra intake but ...megh, lot of work and I'd need a tune hardcore.
