My aode has been giving me troubles about going into neutral, and it gets rough when slowing down. (shaking)
Replaced the mlps, mlps wire and its got good, full fluid.
I checked the codes the other day and it gave me 654, which is
Transmission Range sensor not indicating "PARK" during KOEO self-test.
What could this be?
I have posted the Diagnostic routine at http://www.guardcows.com/ford in the appropriate directory. You will want to look at the file named 95_MLPS.pdf for reference. It also mentions something about needing a special tool. For more information this CD can be downloaded from http://www.fordcds.com
(I assumed it was the mustang in your profile :))
Okay, I took the pcm out and probed the pins on the harness. Got the following results. 30 and 37-80.8 ohms, 30 and 57-92.5 ohms, 37 and 57-21.1 ohms, 40 and 60- it showed some numbers momentarly, 30 and 40-102 ohms, 30 and 60-open, 30 and 46-open, 30 and ground-showed numbers momentarly.
ANy ideas on what to do next??
The pcm and TR sensor has both been replaced also.
