My orange light came on today.
PO171: Bank 1 lean.
Any ideas on what may fix this. I cleared the code, and it hasen't came back yet, but I still want to get it taken care of.
Astrophysicist / PostWhore
PO171: Bank 1 lean.
I went through my Ford Manual on CD. I'm just copy/pasting, so you'll have to read through it all...
P0171 System (adaptive fuel) too lean (Bank #1)
Diagnostic Trouble Codes (DTCs) P0171 bank (1) (cylinder #1) and DTC P0174 bank (2) indicate the fuel/air ratio is too lean. The fuel adaptive system is at the rich correction limit.
DTC P0172 bank (1) and DTC P0175 bank (2) indicate the fuel/air ratio is too rich. The fuel adaptive system is at the lean correction limit.
DTCs HO2S Reference list:
-- HO2S-11 = DTCs P0171 and P0172
-- HO2S-21 = DTCs P0174 and P0175
Possible causes:
Fuel system
-- Excessive fuel pressure.
-- Leaking fuel injector(s).
-- Leaking fuel pressure regulator.
-- Low fuel pressure.
-- Contaminated injector(s)
Induction system
-- Air leaks after the MAF.
-- Vacuum leaks.
-- Restricted air inlet.
-- PCV system.
-- Fuel purge system.
-- Improperly seated dip stick.
EGR
-- Leaking gasket.
-- Stuck open EGR valve.
-- Leaking diaphragm.
Base engine
-- Oil overfill.
-- Cam timing.
-- Cylinder compression.
-- Exhaust leaks before or near the HO2S's.
l Check air intake for leaks, obstructions and damage.
l Check air filter, air filter housing for blockage.
l Verify integrity of the PCV system.
l Check for vacuum leaks.
i had exactly the same code and i checked all the possibilities mentioned above from my shop manual. it turned out to be a dirty maf (i'm not saying it's not one of those indicated above, just giving you another option)
