1 - 18 of 18 Posts
I was lookin at some coil packs and im not sure which ones to get. Ive always liked MSD and i found MSD coil packs for $70 each. Then theres some accel for 61 each, then theres the screamin demon ones off of SCP which are around 100 for both.. Price difference for each are not to bad, i was just curious which worked best with my 4.6(NPI).
The Accels are rated at about 10% more efficient than stock. As for the MSD and Screamin Demons, I have no idea.
I run the Accels on my car and really couldn't tell much, if any, difference over stock.
Here are the Numbers and specks for the Accels from Jegs.
  • 42,000 volts
  • Direct bolt-in, plug-in replacement
  • Advanced section bobbin technology
  • Compatible with Ford EDIS and MSD or Crane DIS
  • Silicone magnetic steel core with optimized windings and resistance for higher energy output and longer dwell
  • 8% peak increase in voltage over OE
  • 9% peak increase in current over OE
  • 11% peak increase in energy over OE
  • 21% peak increase in arc duration over OE
  • Secondary towers molded in high-dielectric strength ''Accel Yellow''
http://www.jegs.com/i/Accel/110/140018/10002/-1
what about performance wise?
what good would other brand coil packs be, if you may have to keep returning them/exchanging them over and over and over?? tell me what kind of performance that may be called
I have tried screaming demons and they worked ok for me...Performance increase...none noticed. No one i have ever seen proves it worthwhile to buy more expensive than stock coils. Buy new ford ones and save money for other performance stuff or good old fashioned maintenance.
stock coil are good for the 400hp area so why upgrade when its just a waste of money
new stock = best choice for durability, reliability and performance.
Plain and simple....you will not see any performance gains by switching coil packs.
I tried finding an old magazine of mine (MM & FF) where they did an ignition upgrade on a 96-98 Cobra. They dynoed the car with the stock wires/packs and then switched out to Screamin Demon coil pack and live wires. After putting it back on the dyno, they picked up a wopping 1.2HP.........save your $$$ for something else.
Thanks guys.... prob save for PI swap.
yeah, i went w/ the MSDs on my car and didnt notice a bit of difference. however...i did notice that there is less money in my wallet after having bought them as opposed to stock replacements...bummer.
I use the BWD(Borg Warner) aftermarket oe replacement coil packs on my '97 and they are just as reliable as the Ford ones plus they cost less. I bought them through one of the parts stores that the shop I work for uses as the BWD rep said that BWD makes a lot of the ignition parts for the automakers and just put either Ford, Motorcraft, GM, or Mopar on it.
Related questions:
1. Does anybody have experience (good or bad) with the Granatelli Pro Series coil packs? These claim to be 60,000 volts and have a lifetime warranty. $130 for a pair at Summit Racing.
2. Were any of the cars (where no improvement was noted) supercharged?
Keep in mind that a coil only works as hard as it has too. I other words, with out an increase in cylinder pressure, the stock coil packs are plenty good. A good spiro core plug wire is helpful though, less resistance than a carbon wire. Just my 2 cents
1 - 18 of 18 Posts
