i have a k&n panel filter on my cougar now and was wondering if it would be worth getting a cold air intake put on
Make your own. I just completed mine. One RichardM tube (look in for sale forum for RichardM's post if you dont know what that is) and then some parts from home depot and part of your stock air silencer. Then you have a complete cold air intake. They usually sell the parts from the MAF to the filter (in the fender) for around $150-180. Its about $30 of parts from home depot and a filter. Same results.
I think I will work on a tech article for a relocation of the filter to the fender using a Cone filter. Maybe next week.
good luck,
-Shawn
If you don't want to go through the trial and error of getting parts to fit, check out Ebay, the Densecharger kit is everything you'll need, it includes ABS plastic pieces that will fit your maf a gasketed plate to cover the hole from the stock air box and a K&N cone filter to go in the fender well. I had to open up the holes a little to match the bolt pattern but it was real minor. A little pricey but all design work is done for you and with my schedule it's like trying to find time to do mods is at a premium and it was easier to go this route. I'm sure there's a performance gain just not very noticable without a dyno, sounds good though.
