Like the title says, I ended up having to replace the air ride with coil springs because the car would never lower itself to the normal ride height after forgetting to turn off the suspension switch. The was car jacked up like a 4x4, never could figure it out. To bad, because the air ride worked great before that happened.
Anyway, I ended up getting a Strutmaster kit from a Mark VIII at a u-pull yard here locally. Front went on fine, ride height looks normal. Now for the rear, I cannot get the rear end to sit at normal ride height no matter what position I put the coils in (probably had them in and out 5 times), and I did look online for the correct way (even looked at Lou's video). I even called Strutmasters to get a pic of the correct orientation and their response was I need your invoice #, I said I don't have one. They said they could not help me. Needless to say I will never buy a Strutmasters part going forward.
So, unless I just a complete idiot (probably am), I have decided that the only way this will work is to cut some of the spring off on both rear coils unless someone here can give me direction on how to install these correctly. I have another kit, the same problem, sits to high in the rear, like a few inches to high.
Thanks in advance
Mike
Thanks in advance
Mike
