Same place it is on all other MN12's. Remove the passenger side kickpanel and look up. You'll see a large black connector with a 10mm bolt head in the middle of it. That is the EEC harness connection to the EEC.
-Rod
Yep, unbolt the connector from the EEC, remove the 7mm bolt attaching the lower rear corner of the EEC bracket to the body, then slide the EEC out.
-Rod
