i havent pulled them out and really looked at things yet but i i just wonderin, i wanted to make more room for a sub box and i was wonderin if i could lengthin the wires for whatevers up there and mount them in the spare tire well?
thanx devan
I forget what they are, but isn't it a LOT of wires? If you do it let me know as I will probably follow suit.
Julian
one of them is ABS computer, if so equipped another is for variable P/S assist if you have it, another is for keyless entry, agan if you have it, and if you have premium sound one is an amp, albiet a very cheesy amp.
Mike
Actually the 3 are:
1. ABS Computer
2. Ride Control Computer
3. AMP for Radio
*(KEYLESS ENTRY) is located in the rear passenger Trunk Well behind carpet, it's a fairly big black box. *
Do you have a 60/40 fold down rear seat? If you do not, then you could take the whole rack down and mount it on the back of the seat back. You then, at this point will not have to do anything as far as to add wire ( A simple swap. I did that at first before I switched over to the fold down.
Hope this helps out.
Jeff B.
