Is there such a thing as a grade 8 metric flange bolt? Or does grade 8 only denote standard sizes? I have tried searching google, but am not sure I understand. I saw one site that states 10.9 metric is roughly equivalent to grade 8 standard. I am asking because I broke the one of the rear differential's bolts that mount it to the crossmember and want to replace it with the same.
It is M12-1.75x85.
seth
Metric equivalent would be 10.9
Chapter Director Coordinator
thats a big bolt to break lol
you're telling me.. especially while laying on your back. i was following the torque specs, but apparently I shouldn't use the upper limit of the torque specs (70-155ft lbs if memory serves me). Torque wrench set at 150ft lbs, only one bolt made it. :) Thanks again for your help James in my spazzing out episode.
Seth
if you didn't go with the high end of the torque specs, then how long would it have been before stress broke that bolt? I would just say obviously it was ready to go.
at the same time you kind of have to have a feel for bolts, and recognize weather or not your tightening it or twisting it.
I don't do any extreme driving or racing, so I will probably just torque to around 100 ft lbs this time. I will also replace the bolt that survived, just to be safe.
Seth
