Those controls are for a different version. Basically up arrow and down arrow for forward and reverse, Space for brake, Q for chute, W for upshift and E for downshift. The bar to the bottom right is tire temp. If it is in the green you'll do good. The transmission/gears stall and launch rpm are controlable and very important. Don't overheat the tires during burnout.
Alan
Found a "glitch" in the game . . . don't look if you don't want to cheat :D
After registering, you can spend your cash. Then click the jack stand (garage), then registration, then hit skip. You get $5000 to spend again. Keep doing this and you can buy buy buy. I've got a camaro running in the low 6's now doing this :D
