Can someone tell me or show me a picture of where the coolant system drain plug is because I just changed my heater core and I want to give the system a good flush.
either pull the bottom radiator hose if u want to drain it quick or loosen the petcok on the passenger side of the radiator to let the coolent drain out
I'm not sure if the iron blocks have the block drains in the same locations as the aluminum blocks, but they ought to. You can see the block drain plug directly under the second freezeplug (same on the other side). Unfortunately, you can't get to them without pulling the motor mounts.
-Rod
